Door glass not working correctly
Old Jan 30, 2023 | 01:59 PM
EZED's Avatar
Default Door glass not working correctly
After setting glass close position passenger side does not function properly. It pops down to clear convertible top while opening. As soon as you release the handle the glass pops up and then will not close. Any suggestions?
Old Jan 31, 2023 | 01:00 PM
STLTHMSTA's Avatar
Have you done a rest?? There are several threads of same on the forum. All the way down, hold button, click, click. All the way up, hold button, click, click. TM
Old Jan 31, 2023 | 05:28 PM
EZED's Avatar
Thanks, tried hold down click, click a couple of times did not solve problem. Window drops to openbut when I take hand of door handle the window raises to close position.
Old Feb 1, 2023 | 04:04 AM
STLTHMSTA's Avatar
Did you do this with the button inside or the handle outside? Sorry I wasn't clear on this but set it with the inside button. TM
Old Feb 1, 2023 | 06:02 AM
Jon89's Avatar
Could be a failing battery. Could also be a failing microswitch inside the door latch assembly....
Old Feb 1, 2023 | 10:06 AM
EZED's Avatar
Seet button from inside down hold 5 seconds and same for up. Window tops up and down correctly. When I open door from inside or outside window drops 3/16" to clear weather stripping. Problem when I take hand off door handle the window does not satay at the 3/16th drop. It goes back up to the original stop position and the door will not close because the window will not clear the weather strip.
Thanks,
EEH
Old Feb 1, 2023 | 10:10 AM
EZED's Avatar
Battery is fine. I will work on the microswitch possibility.
Thanks,
EZED
Old Feb 1, 2023 | 12:45 PM
EZED's Avatar
Looks like failing microswitch inside the door latch assembly is the answer. Just bought one. When I get into the mood I will install it.
Thanks,
EASY
Old Feb 1, 2023 | 07:59 PM
Johnken's Avatar
Ez, wish you posted year. Different circuits different years!
John
Old Feb 2, 2023 | 09:01 AM
EZED's Avatar
John, 2003 XKR
Thanks,
EZED
Old Feb 3, 2023 | 12:28 PM
Johnken's Avatar
Thanks EZED, earlier years tied the puddle light to the microswitch, so that in conjunction with the dash read-out (DRIVER DOOR OPEN) could be used to diagnose.
Looks like you've got it covered though. I don't recall if you need to hold the window in a raised or partial raised position for this job. If not file this away:
Easy way to securely hold window in any raised position when disconnected from regulator arms - just grab a Stanley type trigger clamp, some call it a bar clamp. The soft rubber grabs the glass gently, ez to set clamp force without worrying about overdoing it. One clamp pad on each side, window can't drop.
John
Old Feb 3, 2023 | 02:39 PM
EZED's Avatar
Thanks for the input. Window has to be up in order to remove lock assembly.
Thanks,
EZED
JV911
Exterior
Feb 18, 2019 10:27 PM
Pete Mantell
Jun 7, 2018 08:22 PM
jtdurett
Apr 26, 2015 09:00 PM
coolhotblue
Aug 8, 2012 01:20 AM
JoukoN
May 9, 2012 03:39 PM
