Door handle and latch issues
Old Jun 23, 2009 | 08:09 AM
xsvjag's Avatar
Hi there-
I think the reason your door latch isn't working properly is because your window can't automotically drop a fraction of an inch when you open the door.
I had this very same issue last week after getting mine back from the repair shop. I'm not sure if the battery got disconnected (although all other electronis worked fine). In any case, everytime I pulled on the door handle, the window would go down another inch or so. So I fully rolled up the window while the car door was open and closed it. The door "bounced" and did not latch properly. It's because of the seal and there is a warning in the manual, to drop the window somewhat when there is no power so that you don't damage the window or the seal.
In my case I just had to reprogram the windows and the problem was solved.
I know this isn't much help as it doesn't repair anything but I'm thinking that there is probably nothing wrong with the latch. Maybe one of the other forum members can give you insight on dropping the glass just a smidge manually, till you get it repaired.
Old Jun 23, 2009 | 10:31 PM
H20boy's Avatar
You're going to have to get inside that door panel. Be very careful in there, I have been told about horror stories of the global close/open being triggered and people getting fingers lost in there. Door latch is most likely working its way loose...bolts. latch mechanism is a part that does go bad in these xks...both of mine have been replaced after only 5 years of use. Window problem is probably regulator, but can be confirmed once you get it accessible and can check power to it. Time for door surgery.
Old Jun 23, 2009 | 10:32 PM
H20boy's Avatar
as for new/used/salvage parts, try motorcars ltd in houston, ask for Ken. he's a supporting member here and can get you good prices compared to dealer.
Old Jun 25, 2009 | 01:27 PM
H20boy's Avatar
Good call, Ken has access to salvage parts too in addition to new. Lots don't even appear on his website.
Andy (jagtechohio) has a good supply of good used parts also if Ken can't help you. You can find him on here roaming around here fixing things.
99xk8guy
Sep 29, 2025 10:51 PM
Wolfy
May 28, 2024 08:06 AM
PMKimpton
Aug 3, 2019 08:22 PM
XJsc-guy
Nov 23, 2015 01:56 PM
Dz1rfj
Sep 16, 2015 03:44 PM
