door won't lock after paint job - RESOLVED
Old Jun 12, 2014 | 04:51 AM
mark campbell's Avatar
Default door won't lock after paint job - RESOLVED
painted my 1998 xk8 --in order to facilitate it i took off the exterior handles -now it wont lock --lock-unlock ---then goes into alarm when i use remote--------any suggestions --thanks in advance
Old Jun 12, 2014 | 05:57 AM
jimbov8's Avatar
I would say from the sounds of it, you have misaligned something on refitting.
You may have to take it apart again to make sure everything is lined up correctly. Probable cause is the door ajar switch.
Hope this helps,
Old Jun 17, 2014 | 05:00 AM
first thanks for your reply jim----------------found what was wrong---------had the door panel off also !!!!!!!!!well i re-plug the window switch and hung it on the door handle----------well i guess ---3-6 oz is enough to cause problems with the door lock operation ----------anyhow problem solved
Old Jun 17, 2014 | 05:24 AM
jimbov8's Avatar
Glad to hear you have sorted the problem. Happy days
99xk8guy
Sep 29, 2025 10:51 PM
dsnyder586
Dec 29, 2024 07:39 PM
Harry Dredge
Oct 4, 2024 05:37 PM
XJsc-guy
Nov 23, 2015 01:56 PM
WinterJag
16
Oct 9, 2015 07:49 PM
