Drivers side(left) window acting strangely
Old Dec 30, 2024 | 05:46 PM
Pantera928's Avatar
Default Drivers side(left) window acting strangely
the left side window regulator makes the window go up to high when the door is opened from the inside. If you open the door from the outside, the window drops slightly as it should.
Any ideas what could cause this?
Old Dec 30, 2024 | 07:16 PM
zray's Avatar
You need to re set the window memory.
you can search the forum for the procedure.
Z
Old Dec 30, 2024 | 09:50 PM
Pantera928's Avatar
I wish that was the case but it is not. I am very familiar with that procedure
Old Dec 30, 2024 | 11:03 PM
zray's Avatar
Bad battery is the #2 cause.
are you using a battery tender from a recommended manufacturer ? Like a NOCO or a CTEK ?
even good batteries need a battery tender to keep the electrical gremlins away. Sounds too simple to be true. But that is the experience of numerous forum members. Just hooking up the tender when the car is sitting overnight or longer will work wonders.
Z
Old Dec 31, 2024 | 02:40 AM
dibbit's Avatar
I would be looking at the various microswitches in the door handle/latch mechanism. It does sound like the car thinks the door is being closed rather than opened.
Old Dec 31, 2024 | 08:41 AM
Pantera928's Avatar
It is definitely not battery related and is only an issue on the drivers side door. If you open the door from the outside using the handle, the window drops as it should to allow you to open it but goes back up when you release the handle.
Switches in the door are the next thing I might check although i am not familiar with all of that,,,,,,,,,,yet
Old Dec 31, 2024 | 10:22 AM
bladerunner919's Avatar
Just to clarify - do you mean that it doesn't drop (ie, does nothing) when opened from the inside, or that it tries to go further up?
Old Dec 31, 2024 | 02:36 PM
Pantera928's Avatar
it goes farther up when opened from the inside. Probably to the limit of the regulator travel
cstrad_8
May 13, 2024 04:10 PM
Bob Hornby
Sep 20, 2021 12:34 PM
martek
Sep 13, 2018 06:02 PM
G-Man
Oct 22, 2011 10:56 AM
