drivers window switch
Old Apr 16, 2017 | 12:05 PM
macs99's Avatar
Question drivers window switch
Hi guys rebuilt car from ground up and am stuck on changing drivers side window switch. Age must be catching up, any help would be appreciated.
Old Apr 16, 2017 | 12:28 PM
avern1's Avatar
You will need to remove the door card. Once that is done you can separate the arm rest and you will be able to access the mounting for the switch assembly.
Old Apr 16, 2017 | 01:06 PM
macs99's Avatar
Thanks for your help i think i went brain dead.
