Easy fix?
Old Oct 10, 2020 | 02:40 AM
alanroberts50's Avatar
Default Easy fix?
So there’s what appear to be 2 matching sensors on the cam covers at the front of the engine left and right...
the one just forward of the dipstick seems to be oozing a slight amount of oil. How do I cure this, is it just a case of tightening the sensor by screwing it in a bit? By hand or is it threaded needing a wrench? Do I need to remove the sensor first and if so how?
thanks
Alan
Old Oct 10, 2020 | 05:45 AM
Jon89's Avatar
Sounds like you are referring to the VVT (Variable Valve Timing) solenoid O-ring seals. They bake in the engine bay heat and eventually get hard and inflexible, which allows them to begin to seep oil and air, sometimes throwing OBDII codes as a result. For me, they typically last two to three years before needing to be replaced. I last ordered them from rockauto.com in January 2019 and paid about $15 for the pair. The part number is AJ82856....
You simply pry them up with a very small flat-blade screwdriver, clean the area thoroughly, and seat the new ones into place very carefully so you do not deform them and cause them to leak right off the bat. I use the tip of a small wooden dowel to press the new ones firmly into place....
Removing all traces of oil and grime around the solenoid is key to getting a snug, seep-free fit....
Old Oct 10, 2020 | 08:08 AM
Thanks so much Jon, I am guessing they are the original seals or at least 8yrs old as that’s how long I have had the vehicle!
Old Oct 10, 2020 | 08:25 AM
Aarcuda's Avatar
Great topic and I have the same problem
are they just regular shaped orings or are they weird flat sided things? Because I have a whole assortment of orings I could use to match dimensions but I dont want to try and find I need a special size or shape
Old Oct 10, 2020 | 08:42 AM
cjd777's Avatar
Alan, have a look at this advertisement and you will see it's not a regular shape.
https://thmotorsports.com/4854139-ap...saAvnBEALw_wcB
Wayne
Old Oct 10, 2020 | 10:27 AM
Markel's Avatar
When you change them, as stated clean the areas. BUT if i where you i would not try and put them in dry, a very light smear of white lithium grease or lube of your choice, if you try and put them in dry it will be a bear and you will most likely tear something.
Traveller
Feb 27, 2020 10:13 PM
Vee
Jan 27, 2018 05:51 PM
kurtomatic
Oct 23, 2015 11:57 AM
molczyk
XJ XJ12 ( X305 )
Apr 20, 2014 08:04 PM
harryco
Nov 3, 2013 07:14 AM
