ECU
Old Nov 15, 2020 | 04:37 PM
bazmarley's Avatar
Default ECU
Hi I stay in Scotland and have been having trouble with my ECU XK8 2006 does anyone know where I can get a replacement need to get one before I get my MOT in January 2021 thanks for any help Bazmarley
Old Nov 15, 2020 | 05:44 PM
crbass's Avatar
A couple available on ebay in the US, but what are your symptoms?
https://www.ebay.co.uk/itm/2006-Jagu...sAAOSwe-5e0dZZ
Old Nov 15, 2020 | 06:53 PM
bazmarley's Avatar
It has a brakes fault, keeps beeping when I drive, even as there is nothing wrong with the brakes, also I need to keep my finger on the red start button for a few seconds to start with the brake pedal as if not it will add further faults thanks
Old Nov 15, 2020 | 09:29 PM
crbass's Avatar
Unless I'm mistaken, sounds like you have an X150, with a start button (generally model year 2007-2014), not the X100-103 (this forum). Ignore my reference to a 2006 XK8 ECM. That probably will not work for you, and you'll likely need to discuss your issues in the X150 forum.
It might be helpful, there, if you posted your codes from the car scanner and why you think the brakes are working, but the warning light is the fault of the ECM. Good luck!
Old Nov 16, 2020 | 04:04 PM
JagV8's Avatar
Changing which "ECU"? Don't even start - read the codes.
AMC
Apr 21, 2018 11:06 AM
BaDAss03STR
Sep 10, 2008 09:18 AM
BaDAss03STR
Sep 10, 2008 09:17 AM
BaDAss03STR
Sep 10, 2008 02:57 AM
