Engine cover screw.
Old Nov 30, 2010 | 09:11 AM
jagpro69's Avatar
Default Engine cover screw.
I have a 2006 Jaguar XK8 with a missing engine cover screw. The plastic cover is held in place with 4 screws and the oil filler cap must be removed to remove the engine cover. Does anyone know where I can buy one of these screws?
Old Nov 30, 2010 | 11:26 AM
XKRacer's Avatar
You will probably find you can buy one from Jaguar, every part normally has its own part number even bolts and screws
Old Nov 30, 2010 | 12:18 PM
jagpro69's Avatar
I did call my local Jaguar dealer parts dept., and they told me that I would have to buy the whole engine cover to get the 4 bolts.
Old Nov 30, 2010 | 01:20 PM
hardmat's Avatar
If all else fails, take one of the 3 remaining fasteners to a GOOD hardware store and find a nut that the fastener will screw into with a good fit, no wiggle or looseness to it. I am guessing this fastener has "fine" threads as opposed to "coarse" (spacing between the ridge of each thread). For a good fit, you will need to match up a fine threaded fastener with a fine threaded nut. Once you have determined the correct size of the nut, it will be easy to fine the correct sized fastener. Fastener material, length and type of head are the only other things you really need to consider at this point.
Old Nov 30, 2010 | 01:21 PM
XKRacer's Avatar
Thats quite surprising, like I said 'normally' everything is seperate, to be honest I cant even remember what one of these screws looks like, all I can suggest is try some Jag breakers
Good luck
Old Nov 30, 2010 | 03:15 PM
GordoCatCar's Avatar
On my '97, the outboard (bottom) of the decorative engine covers are held in place using two rubber caps that slip through the cam covers and then slide onto two 5mm studs which are part of the cam cover bolt pattern. Do you still have the studs on the cam covers?
Old Dec 1, 2010 | 02:23 PM
steve11's Avatar
ud
The four fasteners on the 4.2 engine cover are not really screws, but 1/4 turn twist locks, and no, they're not sold separately. If it were me, I'd head over to Ebay and buy a used cover. You'll not only have three spares, but an extra cover too. Here is one. Guy wants $50 or offer. I'd offer something lower and fix the problem that way
http://cgi.ebay.com/ebaymotors/2004-...item33606308de
Forcedair1
Sep 8, 2025 01:57 PM
dsnyder586
Dec 29, 2024 07:39 PM
XJsc-guy
Sep 25, 2015 11:09 AM
KarimPA
Sep 12, 2015 08:15 AM
KarimPA
Sep 3, 2015 07:32 PM
