Engine light still on-1 code found! ???
Old Jan 23, 2023 | 02:49 PM
JAG8GUY's Avatar
Default Engine light still on-1 code found! ???
Ok I got 1 code pop up - P0442 Evaporative Emission system leak detected (small leak) SEE PIC
how critical is this ?
Old Jan 23, 2023 | 03:34 PM
kstevusa's Avatar
P0442- Simple as Fuel Filler Cap loose or gasket damaged to Failure of the Evap Canister or hose lines leaking or Evap Canister close valve failure or fuel tank leak. Source Page 38 2003 Jaguar DTC --P codes
Old Jan 23, 2023 | 03:35 PM
NorXKR's Avatar
Not critical.
Has had the same on mine for two years.
Changed the fuel filler cap - didnt help
Changed the O-rings on both charcoal canister - didnt help
Search forum and you will find several answers
Old Jan 23, 2023 | 04:21 PM
JAG8GUY's Avatar
NorXKR...thanks for the quick response and good info...appreciate it!
skidman
Dec 20, 2022 10:42 AM
bfx308
May 15, 2022 08:18 AM
Camwad
Sep 5, 2021 12:16 AM
RaceDiagnostics
Oct 29, 2019 12:14 PM
sweatyfox
Jan 19, 2017 01:10 PM
