Engine Number
Old Jul 21, 2017 | 11:32 PM
EZDriver's Avatar
Smile Engine Number
Can some one give me a good description as to where the engine number is stamped on the 2000 XK8 Jag. Maybe a picture even. I really need to know what the number is.
Thanks guys
Old Jul 22, 2017 | 08:12 AM
RJ237's Avatar
It's on the top of the block, just to the left of the thermostat tower. You will have to get on top of the engine with a flashlight to find it.
Old Jul 22, 2017 | 08:19 AM
motorcarman's Avatar
Depending on when the engine was made it can also be stamped into the left side behind the engine mount area.
bob
Old Jul 22, 2017 | 02:11 PM
EZDriver's Avatar
bob
Hi Bob, I have tried many times and have yet to find that number. But, due to the build date of the car being May 2000 on the door frame I think I can assume that I have Nikasil cylinders. I have owned the car for seven years and have never had any problems with starting as I always run the engine until it starts to warm up and it idles down before I even put it in gear. However recently I have noticed some oil consumption that I don't like. Don't know what else would cause it. What would be the accepted oil usage with Nikasil?
I also noticed that the top radiator hose was partially collapsed until I opened the expansion tank. Is this unusual?
Thanks Bob
Old Jul 22, 2017 | 04:38 PM
Sounds like you might need to replace the coolant system cap. It is supposed to draw fluid to the system from the atmospheric catchment tank upon cool-down.
Check TSB 600-03am3 Part-Load Engine Breather.pdf for proper crankcase breathing.
bob
Old Jul 24, 2017 | 05:39 PM
EZDriver's Avatar
bob
Thanks Bob, I will check the breather system as soon possible. I am mystified as to why there is a no no about doing the TB is there is a certain message on it. Strange.
Also, do you have a link to TSB 310-06 for cleaning the TB. I wouldn't think it would be very difficult.
I really appreciate your help.
Bob
Old Jul 24, 2017 | 05:51 PM
The throttles are supposed to have a chemical coating.
The early ones have the procedure to clean.
bob
File Type: pdf
Old Jul 24, 2017 | 07:35 PM
RJ237's Avatar
Bob seems to have answered your questions, as usual. I would only add that my nikasil XK8 used about 3oz. in 3000 mi. at 100,000 mi.
Old Jul 24, 2017 | 08:18 PM
I usually don't answer the question but post JAGUAR's answer to the question.
I have a penchant for collecting and distributing info.
bob
Post Script
I have been using Castrol 10W40 High Mileage oil since my XJs have over 100K miles. They do use some oil between changes and I am here in Texas. Temps can get high in the Summer and not too severe in Winter.
Old Jul 25, 2017 | 09:28 AM
EZDriver's Avatar
Bob, I don't know what we would do without you. Thanks much for the TSB. I intend to attack this problem this afternoon.
Bob
