Engine Surging (mild)
Old Jun 14, 2022 | 10:37 AM
Norm 427's Avatar
Default Engine Surging (mild)
At light throttle going 25 mph or 30 the rpms go back and forth from about 1400 to 1500. It's annoying but it disappears at faster speeds.
There was a thread about this a couple years ago but I can't find it.
Is it the tranny locking up and unlocking? A dirty throttle body?
TIA. Norm
2003 XK8 Convertible 105k miles
Old Jun 14, 2022 | 04:30 PM
wymjym's Avatar
TIA. Norm
nothing ever absolutely has been confirmed that I have read, typically it is a bit of slippage in the torque converter...new fluid might resolve it for a while, a new tq will probably solve the issue, a rebuilt tranny will probably...etc, etc.
The fluid change should probably be the 1st step. In my case I drive it in 3 until warmed up and then when placed in D everything was fine.
wj
Old Jun 14, 2022 | 05:12 PM
CA Jag's Avatar
For 03-06 6 speed, is the ATF change at 50-60k a must do like the 5 speed? Also my 03 doesn't surge but makes a slight noise ("chirp") shifting from 5 to 6. Local indy said Jag recommends adding a 1 quart of something designed to improve solve the problem. Good idea? Would this also help the surging being discussed?
Jack T. Harper
Apr 25, 2022 10:09 PM
Jack T. Harper
Apr 16, 2022 03:27 PM
Jaguar2373
Mar 15, 2022 11:56 PM
Lannyl81
Jan 1, 2016 01:21 PM
DevonDavid
Mar 18, 2014 12:18 PM
