Engine won't blow up
Old Oct 5, 2014 | 12:02 AM
dareandgo's Avatar
Default Engine won't blow up
Drove to Florida with low oil pressure which makes almost 2500 miles since the light lit.
Old Oct 5, 2014 | 12:15 AM
Jandreu's Avatar
You crazy or what?
Old Oct 5, 2014 | 12:33 AM
dareandgo's Avatar
Did it. She didn't even blink. Women are so unpredictable. It's either bad bearings or Tensioner Body crack.
Old Oct 5, 2014 | 03:31 AM
srad34's Avatar
Don't bite, this has troll written all over it lol
Old Oct 5, 2014 | 10:50 AM
dareandgo's Avatar
1200 miles from AC to Miami.
Met some guy with a 2003 XKR "show-winner" (pale blue) who knows Reverend Sam (from NJ) along the way.
He said, "you're not a troll" and your 97 Sherwood Green Coupe is rare.
Read that bite.
Old Oct 5, 2014 | 11:11 AM
Mikey's Avatar
You've never said what sort of oil pressure the engine makes at normal driving RPM. If those are within range, the engine might go for a very long time as-is.
Old Oct 5, 2014 | 11:52 AM
dareandgo's Avatar
Thanks Mikey. I watched the Jag Tech with the mechanical gage connected to the engine showing normal oil pressure above idle.
Old Apr 17, 2015 | 09:50 AM
dareandgo's Avatar
She is still running with over 98000 miles on the clock (5000 since warning) and no action on my part to correct anything.
Seems like low oil pressure warning is not always fatal--
Old Apr 17, 2015 | 11:08 AM
Probably not going to blow up due to oil pressure then.
Old Apr 17, 2015 | 11:58 AM
dareandgo's Avatar
egg zackly Norri.
This is what I"ve been saying.
We as a group are smarter than this car.
Old Apr 18, 2015 | 07:03 PM
motorcarman's Avatar
I would still pull the oil pan and check/clean the oil pick-up screen. It could be done in less than an hour on a lift. If the screen is OK then just drive because it is what you are doing anyway.
If the screen is 'plugged', then clean it and you might extend the life of the engine.
bob gauff
Old Jul 2, 2015 | 08:33 AM
dareandgo's Avatar
well, I have done nothing and it still runs. The assumption of being very careful is not always correct. Not only does it run, it will redline if I ask it to.
Old Jul 2, 2015 | 08:46 AM
dibbit's Avatar
Five out of six people who play Russian roulette don't shoot themselves in the head either.
Good luck.
Old Jul 2, 2015 | 11:38 AM
dareandgo's Avatar
da point is, it is a car and not a museum peice
Old Jul 2, 2015 | 02:43 PM
brgjag's Avatar
maybe the sensor is BAD.
Old Jul 3, 2015 | 12:17 AM
enderle's Avatar
I had a Buick Skylark fully restored similar issue thought it funny until the engine came apart catastrophically near Buttenwillow in 110 degree heat. I was young, I don't take those risks anymore. It was not a happy day. My stepmother had a similar experience with her XKE but she'd thought the oil pressure gauge worked like a fuel level gauge so she at least had an excuse. You blow up an engine at speed and trust me it is a really memorable experience particularly if it locks up the rear wheels. The guy driving the car behind you will likely have a life changing experience at the same time, in my case his car just chewed up big portions of my engine which didn't do his front end any good at all. (though he kept driving and didn't stop for some reason, go figure?). Ended up selling the car for $10. My father, who had given me the car, was not amused.
Old Mar 20, 2019 | 05:16 PM
dareandgo's Avatar
An update on the situation: The car has been sitting for about two years now and the engine NEVER blew up yet. It's for sale now on cars.com.
https://www.cars.com/vehicledetail/d...6611/overview/
Old Mar 20, 2019 | 07:34 PM
scottjh9's Avatar
very nice car...If I had the room to store it, I would fix all that ails it and give it to my granddaughter in 2035 when she turns 18....really like the racing green....
Old Mar 20, 2019 | 07:57 PM
dareandgo's Avatar
Basically, someone's going to take this fine automobile "off my hands" and it could even be you.
I just want out.
Old Mar 20, 2019 | 08:00 PM
dareandgo's Avatar
It's Sherwood Green but thanks.
