Exhaust Manifold
Old Apr 18, 2022 | 05:23 PM
Jay111's Avatar
Default Exhaust Manifold
Put the engine back in my 1997 XK8 after going through it. Can't get the exhaust manifolds into position (not enough space between heads and shock towers).
Any tricks to help me with getting these in would be GREAT, really getting old doing everything twice on this car.
Jay111
Old Apr 19, 2022 | 11:05 AM
bcprice36's Avatar
Jay111.
If they are XK8-XKR Jaguar Manifolds for the AJ-V8 they will fit....All XK8-XKR Manifolds are pretty much the same with the sharp Bend at the Rear that leads to the Cat....The Sedan version of the Exhaust is an little different in that it doesn't make the sharp Bend...It flows on toward the back at an angle....Look up the Part Numbers...
Billy Clyde @ Cinco Ranch
Old Apr 19, 2022 | 01:19 PM
Jay111's Avatar
They are the ones that came on the car. Unless there is a trick to get the drivers side manifold on without pulling the engine again , I can't seem to get it to fit between the fender well and the rear corner of the head.
Thanks,
Jay111
Old Apr 19, 2022 | 09:41 PM
oldmots's Avatar
My suggestion is to unbolt the engine mounts, reattach the lift chain and lift the engine until you can tilt it to allow the manifold to slide on, then do it on the other side.
Old Apr 20, 2022 | 07:28 AM
Jay111's Avatar
Thank You, that was going to be my next thing to try.
THaks,
Jay111
Old Apr 23, 2022 | 12:40 AM
Pistnbroke's Avatar
I hope I don't ever have to take the engine out but I assume you did not take them off before you removed the engine so why did you not put them on before you reinstalled it ?
Beginner
E type ( XK-E )
Jan 26, 2022 10:43 AM
roman_mg
Apr 29, 2019 07:00 AM
Muddybear
Aug 29, 2016 03:43 PM
mclrky69
Jul 5, 2011 03:37 AM
Paul S
Aug 31, 2008 01:03 AM
