Expert Advise needed on seat removal
Old Oct 17, 2012 | 06:11 PM
Kadmiri's Avatar
Default Expert Advise needed on seat removal
I read before you remove the drivers seat or passengers disconnect the battery or airbag may go off and at the same time I read if you disconnect the jaguar completely it wont start and will have to be towed to nearest dealership to be resetted due to a transponder or somthing anyways does this only require a ground cable removed or both thanks
Old Oct 17, 2012 | 06:55 PM
Paul Pavlik's Avatar
Positive Cable only needs to be removed.
The windows will have to be re-programmed. (Procedure in Owner's Manual.)
Some of the Radio Presets may be lost and can be re-programmed. US Cars don't usually require a Radio Code.
No need to visit Dealer.
Rupesh
Mar 25, 2016 03:33 PM
ControlIssues
Sep 3, 2015 07:38 PM
1964Daimler
Sep 2, 2015 11:41 PM
Calhale
Aug 29, 2015 10:39 AM
divingmom
Aug 25, 2015 07:54 PM
