Those expierenced in rattles
Old Oct 16, 2012 | 03:59 PM
mick99's Avatar
Default Those expierenced in rattles
After a year of preventive maintence, took first trip on weekend. Result, dashboard rattle, when hitting bumps. can anyone suggest where to start looking?
Old Oct 16, 2012 | 04:27 PM
Paul Pavlik's Avatar
Pry both Dash Speakers up gently with a Putty Knife and make sure that the Dash Mounting Bolts are tight. Also, the Center Bolt under the plastic cover.
Old Oct 16, 2012 | 04:55 PM
stevepaa's Avatar
Dashboard rattel-usually low pitch. Or does it sound like plastci hitting glass- the front vents?
Old Oct 16, 2012 | 05:54 PM
Jacsun's Avatar
Try opening the hood and tightening the diagonal cross-members (steel bars across corners of engine compartment). When they are loose you will hear a relatively hard knock when you go over bumps that almost sounds like it comes out of the windshield. Jac
Old Oct 17, 2012 | 08:07 AM
mick99's Avatar
Thanks for the info! the rattle has a low pitch.
Old Oct 17, 2012 | 11:24 AM
K.Westra's Avatar
Low pitch probably rules out the defrost vents, but just to cover all bases, here is a fix if that is the problem: https://www.jaguarforums.com/forum/x...nts-faq-45338/
Old Oct 17, 2012 | 10:13 PM
motorcarman's Avatar
Here is some old info we used back in the day!!!
bob gauff
File Type: pdf
File Type: pdf
Old Oct 18, 2012 | 11:40 AM
H20boy's Avatar
How funny, a 'squeak and rattle kit' issued to dealers. I enjoyed that read, thanks Bob.
Joachim1167
Nov 7, 2020 09:18 PM
Dutch xjrdiamond
Nov 30, 2019 09:14 PM
redxk8
Oct 4, 2015 08:28 AM
inactualis
Oct 2, 2015 11:13 AM
millertic
Sep 30, 2015 08:11 PM
