Fail safe engine mode
Old Jul 17, 2013 | 09:02 PM
ahspros's Avatar
Default Fail safe engine mode
I was getting the fail safe engine mode and a P0122 code. During this fail safe engine mode the cat ran very well with no restriction of RPM. Engine went all the way up to 4,500 rpm with no trouble. Replaced the TB with a rebuilt unit did a hard reboot and the P0122 code went away. Went for a test run had cruise control. After a few miles lost cruise control then fail safe engine mode came up. Car still had full RPM range and did not show a code on my reader. I tried to erase the fail engine mode with no luck. Did another hard reboot and fail safe went away. It still returned after a few miles and with no cruise control. Cruise control would try to come on with a small bump in speed but would not latch. This is a 2000 XK8
Anyone have ever have this issue?
Walt
Old Jul 17, 2013 | 09:49 PM
Gus's Avatar
Gus
Are you getting the failsafe anytime with the cruise off?
Old Jul 18, 2013 | 08:44 AM
ahspros's Avatar
It does not matter if it is on or off. Takes about 5 to 10 minutes after starting.
Walt
Old Jul 18, 2013 | 04:50 PM
Gus's Avatar
Gus
The P0122 code directs you to look at the P0121 code that addresses a compatibility problem with the throttle body plugs or a problem with the throttle body.
Link http://www.jagrepair.com/images/Auto...7_ECM_2000.pdf
Link http://www.jagrepair.com/ThrottleBodyPlugs.htm
Link http://www.jagrepair.com/images/TSB/XK8/303-58.pdf
I hope this helps!
Old Jul 20, 2013 | 09:51 AM
ahspros's Avatar
Thanks will try this. Is it possible to get a new or replacement plug as mine do not have the keeper and are chipped on the pin end. The new throttle body appears to have new pins. I have a tie wrap holding them in place now.
Walt
Forcedair1
Sep 8, 2025 01:57 PM
cissdm
May 3, 2016 06:02 AM
Rlover
Mar 30, 2016 10:04 PM
Bowman
Sep 15, 2015 06:54 AM
rachelstr
Sep 3, 2015 12:59 PM
