Failed Emissions / Mode 06 Data Question
Old Feb 8, 2016 | 09:13 AM
keg0brew's Avatar
Default Failed Emissions / Mode 06 Data Question
Hey all, have a question specifically about some Mode 06 data I got on my 1999 XK8.
My car recently failed emissions because my monitors for O2, Catalyst, Evap, and Continuous Component were not ready. I have driven 300+ miles since the test and still the tests are not ready.
I do not have a check engine light, but after looking through Mode 06 data, my software (OBD Auto Doctor) says I did have a "Manufacturer Specified Component $11 / $07-Minimum Sensor Voltage for test cycle (calculated)" Failed result on a value of 0.200V.
Hoping someone can help me decipher that since I cant seem to find an answer via google. Is it the reason those tests will not complete?
Old Feb 9, 2016 | 02:04 AM
JagV8's Avatar
At some point in the past all those monitors were set OK. What happened to clear them? (They don't self-clear.)
How are the fuel trims?
Try smoke test, incl. evap.
Old Feb 9, 2016 | 07:57 AM
keg0brew's Avatar
Thanks for the thoughts.
I had the car shipped across the U.S. And they disconnected the battery during the transport which reset the monitors obviously.
Fuel trims look ok I think...long terms are steadier around 6% and short terms are more variable but says they average around 3% . Does that sound about normal?
Old Feb 10, 2016 | 05:12 AM
JagV8's Avatar
Sadly yes, as if they were out at idle it's quite easy.
You may need to control various of the valves etc during a smoke test - sort of thing beyond most DIYers. Try a good jag tech...
Old Feb 10, 2016 | 11:43 AM
64vette's Avatar
I think it is worth a try to replace the Purge Valve, a fairly easy job, and not that expensive even if you pay an independent shop to do it.
The newer version also adds a filter (simply plumb a small fuel filter to it). Of course every case may be different, that said I had the same problem with my 2000 XK8 and it turned out to be a bad purge valve which of course kept the EVAP from running, but it also kept other monitors from completing too. The bad purge valve did not set a DTC.
KayScotts
Feb 6, 2016 01:03 AM
sawduster
Feb 5, 2016 10:27 PM
t140pete
Jan 25, 2016 08:01 AM
Addicted2boost
Jan 24, 2016 05:35 PM
Tahoe Dave
Jan 20, 2016 09:31 AM
