Fan assembly
Old May 8, 2013 | 02:52 PM
BosseH's Avatar
Default Fan assembly
The fan assembly is attached to the cooler with some kind of nuts! But I canīt find any on my car ( xkr 2001)! I know where they shall be. Problem is that I donīt know what type and dimension on the nuts?
Can anyone help we with this?? Thanks in advance.
Best rgds / Bo from Sweden
Old May 8, 2013 | 05:46 PM
Have you removed the complete Cooling fans and Cowl assembly by removing the two M6 nuts, the electrical harness connectors and lifting it out?
Each of the Fan Motors is secured with three nuts:
There's a washer, spacer and rubber mounting behind each nut.
Attached Thumbnails Fan assembly-xk8-cooling-fan.jpg   Fan assembly-xk8-cooling-fan-motor.jpg
Old May 9, 2013 | 09:04 AM
BosseH's Avatar
Yes I have removed the fan assembly and when I was going to reinstall it I canīt find anything to mount the nuts on!?? Can you help me? See also att. picture.
/ BosseH
Old May 9, 2013 | 09:48 AM
avos's Avatar
The bolts can slide out of the radiator mounts, so they may have fallen somewhere.
But to be honest, I don’t use these bolts anymore to fit it, the fan assembly already perfectly hangs on the #1 part. I have actually cut off the two sides (red circles), so I can now just take the fan assembly out with easy and without having to remove the radiator hose. So besides time and messy work when you disconnect the hose, you also avoid the chance of spilling coolant on the belts, which can cause belt squeal.
Old May 9, 2013 | 10:05 AM
The slot you have arrowed should engage with an M6 threaded bolt and then be secured with a washer and hexagon nut. Same on the other side.
Seth
Nov 1, 2015 12:17 PM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
tomkilner
Oct 9, 2015 07:10 AM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
