Fault code P0197
Old Apr 23, 2016 | 09:11 AM
walkman1's Avatar
Default Fault code P0197
I recently changed the valve cover gaskets since they were leaking oil. I have noticed an intermittent oil smell when the car is not moving since the new gaskets were installed, but there is no oil on the engine or the floor. After a week, the check engine light came on and I have a P0197 code, which indicates "engine oil temperature sensor low". The oil level on the dipstick is down a little. Any ideas?
Old Apr 23, 2016 | 09:31 AM
Paul Pavlik's Avatar
"P0197 code, which indicates "engine oil temperature sensor low"
This says that the Sensor Circuit Voltage is low indicating a HIGH Oil Temperature.
Gus's Avatar
Gus
Attached is a list of codes for your car so you can see the default action and causes. You may want to check all plugs you were working near also do a hard reset and see if it clears.
Link http://jagrepair.com/images/AutoRepa..._2001_OBD2.pdf
Old Apr 23, 2016 | 12:00 PM
walkman1's Avatar
There were no codes prior to the gasket replacement, so I will drop it back in my mechanic's lap.
Gerard Radimaker
51
Jul 1, 2016 07:55 AM
Nee_the_Bogeyman
Apr 3, 2016 10:41 PM
xkeots
Mar 31, 2016 02:03 AM
Dean Kitching
Mar 30, 2016 02:53 PM
XxSlowpokexX
Mar 25, 2016 07:07 PM
