Foam between super charger and block
Old Sep 11, 2015 | 01:41 AM
Super Cat's Avatar
Default Foam between super charger and block
I assume this is to keep the heater hoses from flopping around but seems like the foam would prevent air circulation and cause heat buildup leading to hose failure. What is expert opinion?
Old Sep 11, 2015 | 08:14 AM
ccfulton's Avatar
There will not be much air flow in that area as it is completely surrounded by the intake, heads and supercharger. As such, everything will nominally come to the same temperature regardless of whether it is "insulated" or not.
I put it back when I had my supercharger off.
aode06
Jul 28, 2023 02:26 PM
convincor
Oct 1, 2015 05:19 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
dieseldoc
Sep 28, 2015 01:17 PM
sg997tt
Canada
Sep 27, 2015 02:40 PM
