Fob
Old Oct 31, 2013 | 10:33 PM
Mike Graham's Avatar
Default Fob
Hi All,
Tried to lock the cat & FOB wouldn't work so I tested the battery & it was bad so I replaced it. I then proceeded to lock her & it wouldn't work. I read in the manual that if U push a FOB button it has to be programmed by the dealer. How does one know when the battery is going to take a crap without pushing the button. It doesn't make sense. Could someone shed some light here? All the other cars I have owned had a binding proceedure after battery replacement.
Thanks,
Mike
Old Nov 1, 2013 | 04:01 AM
test point's Avatar
As does your car:
https://www.jaguarforums.com/forum/x...ers-faq-33580/
. . . and if that doesn't work:
https://www.jaguarforums.com/forum/x...graming-10496/
The difference being the reference to depressing button or buttons 5 times.
Old Nov 1, 2013 | 05:05 AM
+1 to test point's links for reprogramming the fob
FOB programming is a DIY job; KEY programming is a Dealer job.
There's usually some warning that the fob battery is on the way out. Normally having to get closer to the vehicle to lock/unlock is a good indication.
You can change a fob battery without losing the programmed link to the vehicle provided you don't press any of the buttons while changing the battery. If you do accidentally press a button (or take too long to change the battery), it will have to be reprogrammed.
Old Nov 1, 2013 | 06:59 AM
Windycityx's Avatar
And maybe clean the inside of the fob if it's black and dirty as well, mine wasn't working last week, cleaned the inside, and now it works fine again, check my other thread with how to do it if you are unfamiliar.
And is it just me or is the range on these remotes ridiculously bad? And take a lot of pressure to make them work?
Old Nov 1, 2013 | 07:10 AM
Originally Posted by Windycityx
............ And take a lot of pressure to make them work?
I've found the early fobs with the coated rubber contacts can take some pressure but the later ones with micro switches only need a light press.
philwarner
28
Jul 11, 2017 10:21 AM
redxk8
Sep 30, 2015 08:18 AM
Listers
Sep 30, 2015 07:45 AM
Jzar
Sep 27, 2015 02:55 PM
