foot rest
Old Mar 30, 2010 | 05:18 PM
Rev's Avatar
Rev
Default foot rest
Is the left foot rest on the floorboard adjustable?
I`m 6-1 and can`t touch it, sure would be nice if is was.
Old Mar 30, 2010 | 05:55 PM
test point's Avatar
GordoCarCat raised it about an inch and a half by using a piece of shop vacuum hose plastic pipe the correct size to fit. That is about all you can do.
Old Mar 30, 2010 | 06:53 PM
Brian2000XKR's Avatar
I put in Arden Foot Pedals, as well as a Dead Pedal on both the driver and passenger's side. It was an expensive route to go............
Brian
steve11's Avatar
ud
Check to see if your foot rest has two recessed holes about 1" in diameter, about 7" apart on a plastic pad. If so, there is an accessory plastic lift that snaps in these recesses that will lift the dead foot pad about 2".
I believe it is a Jaguar accessory. Mine had it, but I'm 6'5" and had to remove mine.
Johnken
Apr 8, 2018 10:21 AM
wichita
E type ( XK-E )
Apr 16, 2016 04:00 AM
vwbusbits
Oct 13, 2015 03:43 AM
JagBrian
Oct 1, 2015 12:52 AM
