Front brake judder
Old Aug 18, 2021 | 04:28 AM
Defender99uk's Avatar
Default Front brake judder
Seems like I need to get some new discs for the front of my 2003 XKR, I have the silver Jaguar callipers, so can anyone advise on which discs are the best value for money to replace existing drilled discs and pads, many thanks
Old Aug 19, 2021 | 08:56 AM
First you need to be certain exactly which brakes are fitted to the vehicle. Unlikely to be the original discs after 17 years and cross drilled discs with silver calipers does NOT in itself guarantee the system is the 'R' Performance option. The standard front disc is 305mm diameter and the 'R' Performance is 355mm.
Brake judder can be caused by uneven 'bite' of the pad on the disc but can just as easily be caused by sticking caliper pistons. Some close inspection before breaking out the credit card is advisable.
OE discs are outrageously over priced but at the other extreme there are some very dubious Far Eastern manufacturered aftermarket ones on the likes of ebay. I use one of the aftermarket Jaguar parts specialists such as Berkshire Jag Components or S N G Barratt. These specialists have a hard won reputation to defend and anything aftermarket from them has to satisfy both quality and price.
Old Aug 20, 2021 | 09:22 AM
Thanks for that, I have the original order specification for the car so I’ll have a look at that to see if it says on there, otherwise I’ll have to get a tape out, before I start taking things apart.
asb
May 28, 2020 12:50 PM
WolfdogXKR
Sep 13, 2017 10:30 PM
IanG
Mar 12, 2012 07:36 PM
