Fuel depressurisation & ‘quick’ release?
Old Jan 14, 2026 | 04:29 AM
pcock111's Avatar
Default Fuel depressurisation & ‘quick’ release?
Trying to remove LH cam cover to change 2nd tensioner. Manual says remove fuel line, though not sure if I can wriggle it out without, anyway: Fuel pressure relief valve is not present as per manual for 2005 xkr x100 and quick release coupling on fuel line says special tool required. Any advice on work arounds?
Old Jan 14, 2026 | 06:55 AM
bladerunner919's Avatar
The 'Special tool' can be bought for cheap: https://www.ebay.co.uk/itm/406555822424
Old Jan 15, 2026 | 05:33 AM
pcock111's Avatar
Thanks. Cover off now without line removal but would appreciate any guidance on depressurisation valve/ method for future.
Old Jan 15, 2026 | 09:40 AM
pcolapacker's Avatar
Me too. Within the last few months I changed the valve cover gaskets on both my 02 XK8 and 03 XJR and didn't need to disconnect fuel line. I've found the manual often has steps that can be worked around. For example radiator change instructions include evacuate freon and disconnect condensor. Can be done without these steps. Finding someone with tiny hands to start the bolts helps.
moonandstars
Dec 25, 2024 11:09 AM
pcolapacker
Apr 27, 2021 10:52 AM
Dymaxxion
Jul 2, 2018 01:00 PM
Vicky Baker
Nov 17, 2017 08:47 AM
wordman
Jul 3, 2012 09:20 PM
