Fuel Filter Replacement
Old Sep 22, 2015 | 04:20 PM
reb1999's Avatar
Default Fuel Filter Replacement
Hi All, tried to replace the fuel filter today. Backed off. I cannot believe the amount of leaking fuel . Under pressure spurting all over the place and does not seem to want to stop.
I've replace quite a few filters in my day. Never one like this.
I think I'll wait tell the tank is almost empty. Maybe that will help.
Is this usual?? tks Rich
Old Sep 22, 2015 | 04:47 PM
Gus's Avatar
Gus
I replaced mine and it should not be a problem. Yes you will have leakage but you will not drain the tank.
Old Sep 22, 2015 | 04:49 PM
avern1's Avatar
The fuel system is under pressure you need to go to the schreader valve on the fuel rack and bleed off the pressure. Put a shop towel over it and mop up the fuel. Doesn't matter if you have a full tank or a 1/4 tank. That pressure has to be relieved first. It is cleaner and neater at the valve on the engine.
Old Sep 23, 2015 | 07:10 AM
reb1999's Avatar
Thank you Vern, yes, I could see a good deal of pressure once I loosened the fuel line. Knew there had to be a trick.
tried to remove the fuse run the engine for a second with residual fuel pressure, that didn't work... Left over from my old carburetor days. thanks again, Rich
toronadomike
Jan 22, 2026 10:13 PM
Sprayall
May 30, 2021 08:13 AM
Sprayall
Sep 3, 2015 07:49 PM
pnwrs2000
Sep 3, 2015 11:55 AM
OkieTim
Sep 2, 2015 12:48 PM
