Fuses for Interior Lights
Old Mar 18, 2012 | 06:57 AM
Bobster1's Avatar
Default Fuses for Interior Lights
Hi Guys
Since removing glovebox on my XKR the interior lights in the footwell and above the windscreen have stopped working along with the glovebox light. Could it be a blown fuse? If so where can I locate the correct fuse as i have no diagrams?
many thanks in advance
Old Mar 18, 2012 | 07:55 AM
Jag13cat's Avatar
Default Fuse Location
Bobster1;
Not sure of your year or model (coupe/convertible), and am not sure of the various changes, if any significant changes, in the lighting?
I have 2001 XKR convertible and the fuses protecting the body processor which in turn power the items you reference are fuses #5-15 amp, and #7-15 amp in the driver's side fuse box.
Two circuits come out of the Body Processor for lamps:
1.) Driver, passenger and rear interior lamp (coupe only)
2.) LH, RH Trunk lamps, glove box and vanity lamps
Again, I am referencing my year and model diagrams.
Old Mar 18, 2012 | 08:15 AM
Bobster1's Avatar
Thanks for the reply Jag13cat. The info is for my dad who is not terribly good with computers so will pass that info on. He has a the coupe but hopefully the fuses will be similar
Old Mar 18, 2012 | 11:39 AM
Could be the fuse Jag13cat has has identified for you or might be the Body Processor Module connector displaced:
JTIS - 2001 XK8 Body Processor Module 86 80 31.pdf
By co-incidence the BPM is in the same area he's been working.
Jpav27
Jul 31, 2022 06:43 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
redrover41
23
Sep 25, 2015 01:33 PM
joseph1945
Sep 5, 2015 07:12 PM
King Charles
Sep 3, 2015 12:40 AM
