Gas smell
Old Feb 19, 2015 | 07:45 PM
dsnyder586's Avatar
Default Gas smell
Thuis is a post for posterity so that anyone running into the same issue might glean.
I have had gas smell every time my XK8 tank was almost empty or over 3/4 full. It got so bad this fall I could hardly drive it. I had played with some of the evap stuff but the same issue occured- 3/4 full, almost empty and when it was hot outside.
What was it you ask?
The weld where the filler neck connects to the tank had a hariline crack. A little epoxy and BINGO- no more smell.
I noticed a TINY smattering of rust around the area and guessed that it was rust from condensation vapor and I was correct. Cheap easy fix and now it is again a joy to drive.
Old Feb 20, 2015 | 12:13 PM
brgjag's Avatar
good work.
aode06
Jul 28, 2023 02:26 PM
hkmcmast
Nov 29, 2015 06:56 AM
workworkwork
Oct 23, 2015 10:26 AM
NathanDD6
Oct 6, 2015 11:20 AM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
