Gear Box error
Old Jan 15, 2014 | 01:47 PM
jam1white's Avatar
Question Gear Box error
hello guys...i got a problem with my 01XK8. its starting to hesitate on take off and sometimes a gear box error flashes. i was wondering is this something major going on or about to happen or is this a diy thing i can repair? i check for error codes and its not giving any error codes. thanks
Old Jan 15, 2014 | 02:40 PM
adhips's Avatar
Have you checked the state of the transmission fluid?
Old Jan 15, 2014 | 08:57 PM
jam1white's Avatar
how do u check the fluid?
Old Jan 16, 2014 | 06:43 AM
RJ237's Avatar
I was afraid you were going to ask that. The procedure is available here in the JTIS which you can download, or do a search for various threads.
Basically, you need the car on a lift or four jackstands. The transmission fluid has to be 30 to 50 deg C. When you remove the fill plug at the right rear of the transmission, with the engine running, fluid will trickle out if it is full. Said fill plug is, of course, right over the exhaust system.
Great design, isn't it?
Old Jan 16, 2014 | 09:46 AM
mike66's Avatar
Depending on your transission skill level, it might be time to find a trans shop you can trust for a diagnostic test. Could be just low fluid and/or time for a filter/fluid change, could be a cable adjust, could be the beginning of A drum failure.
Good luck and keep us posted.
Old Jan 16, 2014 | 04:52 PM
jam1white's Avatar
thanks for the feed back...guys. my gut feeling is its some sensor or cable because i can turn the car off and back on and the error goes away untill i come to a stop and take off again. could the problem be a sensor? and where is the gear box located, is it the fluid pan?
Old Jan 16, 2014 | 09:34 PM
mike66's Avatar
The error comes back because it sounds like your trans is slipping. There are sensors that measure engine speed into the trans and driveshaft speed out of the trans. If the speeds don't match what they should be an error message occurs. Different than a check engine light that wil stay on. Get it checked out before it gets worse and you're looking at a tow.
Old Jan 17, 2014 | 04:34 PM
jam1white's Avatar
guys...do anyone know where the sensors are for gear box errors?
Old Jan 17, 2014 | 06:12 PM
RJ237's Avatar
Inside the transmission.
Old Jan 18, 2014 | 03:08 AM
aardvark64's Avatar
My gearbox did similar things due to low transmission fluid. Turned out the cable loom seal was weeping fluid, so topping the fluid up was only ever going to be a temporary fix. Caught it early enough so there was no long term damage. A transmission specialist replaced the seal and it's been fine ever since.
Hope this helps.
Best wishes, Colin
tomsjag
Jun 10, 2023 10:02 AM
Jandreu
Jun 30, 2022 03:10 PM
Dixie61
Sep 19, 2015 06:29 AM
arnoldmilk
Sep 3, 2015 07:42 PM
