Gear Shift Console?
Old Sep 5, 2019 | 09:04 AM
Jeffpost's Avatar
Default Gear Shift Console?
I have a 2000 Jag xkr convertible. I need to replace the gear shift panel in the center console. The part I need has the P, N, R, D letters on it. I don't need the plastic trim that goes around it. Jag seems to have made several of these for their different cars, and I am not sure which part number I need as a replacement. Can anyone give me this info?
Old Sep 5, 2019 | 09:33 AM
rothwell's Avatar
I think this is what you are looking for, right?
#3 on the diagram
https://parts.jaguarlandroverclassic...on-module.html
Old Sep 5, 2019 | 04:47 PM
Jeffpost's Avatar
#3 on the diagram
Thanks for your input. I hope this part number will be the same for the U.S. version of the car. I tried getting the part from a Jag dealer here in Virginia, but they ordered the wrong part twice.
Old Sep 5, 2019 | 09:03 PM
DavidYau's Avatar
Default Called J Gate module
What is the problem and what are you looking for in your J Gate Module
Common problem is the cover cracks and the rubber gasket underneath perishes.
You can get these these separately.
Old Sep 5, 2019 | 09:55 PM
crbass's Avatar
Recently, I had great difficulty getting just the gasket separately (LNC6197AA now). Everyone who seemed to have it, didn't. Every one I yanked from local junkyards was worse than my original. So, I ended up ordering a whole OEM illumination module that includes both of these parts (I think LNC6195AC for you). It wasn't cheap (~$200), but the gasket design changed to a less friable material in the time between 2000/2001 and now.
One complication was that the 'modern' illumination board that came with the new module no longer illuminated anything but P and R leds. So, I just put the old one back in.
One thing I had no trouble finding in pretty good used condition was the cover that David pictures above. I didn't see anyone selling them separately as new OEM, but I wasn't looking for that.
You might want to call Welsh or Jagbits or Terry's Jag or ... In my experience, you are more likely to get a cheaper and more accurate result, depending on what you need.
deovolente
Apr 28, 2017 10:10 AM
cdnp62000
E type ( XK-E )
Jan 17, 2016 12:51 PM
wabisabi
May 4, 2015 09:34 AM
2004xtype
Sep 5, 2013 08:00 PM
rdp
Nov 4, 2009 07:00 AM
