Gearbox fault when selecting reverse
Old Jan 3, 2011 | 03:27 PM
nigelharley's Avatar
Default Gearbox fault when selecting reverse
Our 1998 XK8 develops a gearbox fault when selecting reverse gear. the fault appears on the dash and the car goes into limp mode.
It appears to happen when the gearbox goes into reverse with a clunk. It appears that the gearbox and engine speed are not in synch. If I select neutral for a few seconds (and let the engine revs drop completely) then select reverse it does not fault.
If I restart the engine the fault disappears. The gearbox seems to be working fine otherwise.
Has anyone come across a similar problem and have any suggested solutions?
Thanks for listening!
Nigel, Cowes, Isle of Wight.
Old Jan 4, 2011 | 11:38 AM
H20boy's Avatar
That maybe your first indication of an A-drum failure. Clunking either going in reverse or 1 of the other gears is very symptomatic.. it's also very common in the transmission. If you do a search on ebay our online you will find reconditioned drums that are beefier than original
Old Jan 4, 2011 | 03:23 PM
RCSign's Avatar
Matt
I learned something new today
Doug
2001 XKR Silverstone
Old Jan 5, 2011 | 02:49 PM
Default thanks
Thank you Matt,Very illuminating!
It is great to understand what might be going on before trying to get it fixed.
Nigel.
Old Jan 5, 2011 | 10:39 PM
H20boy's Avatar
A-drums are a little weak on the xk8'S ZF 5HP24, that's one reason the earlier (pre-2003) xkrs get more reliability respect with its mercedes tranny.
magmedia
Aug 15, 2019 08:54 PM
jtflanaga
Sep 29, 2015 12:59 PM
drbill
Sep 28, 2015 12:46 AM
Woznaldo
Sep 26, 2015 11:02 AM
driver safz
Sep 26, 2015 06:01 AM
