Gerarbox failure
Old Aug 24, 2014 | 05:41 PM
tanngo's Avatar
Default Gerarbox failure
2001 jaguar xkr 20,000 miles. Gearbox service 2000 miles ago. oil filter, connector cables. AGM battery now ca 900 '12/90 oem new bmw 2012. ctek maintenance charger. I use the car and short distances, 1, 2 miles very little. trac message receipt failed to start, random amber TRANSMISSION FAILURE. halt and cleared. any suggestions low battery can cause .¿ TRANSMISSION FAILED I do not speak the language 'forgiveness.
Old Aug 24, 2014 | 05:43 PM
tanngo's Avatar
Español .... jaguar xkr 2001 , 20.000 millas . service caja cambios hace 2000 millas . aceite , filtro , conector cables . ahora bateria AGM 900 ca ' 12 /90 bmw oem nueva de 2012 . mantenimiento ctek cargador . Yo utilizo muy poco el auto y corta distancias , 1,a 2 millas . recibo mensaje trac averiado al inicio , al azar luz ámbar FALLO CAJA DE CAMBIOS . detener y comenzar se borra . alguna sugerencia ¿ puede bateria baja causar FALLÓ CAJA DE CAMBIOS .¿ no hablo el idioma ' perdón .
Old Aug 24, 2014 | 06:33 PM
RJ237's Avatar
You need to read codes. Failure of speed sensor in conductor plate possible. Your english better than my spanish.
Old Aug 24, 2014 | 06:56 PM
tanngo's Avatar
Thanks, where the sensor plate is speed
Old Aug 25, 2014 | 05:23 AM
RJ237's Avatar
On the transmission valve body. But until you have some one read the OBD codes, you will not know what is wrong.
pnwrs2000
Sep 30, 2015 01:56 PM
euphoniaob
Sep 30, 2015 10:50 AM
bydand
Sep 28, 2015 09:47 AM
bydand
Sep 27, 2015 12:00 PM
