getting tensioners replaced
Old 05-01-2013, 03:59 PM
randyb's Avatar
Default getting tensioners replaced
Is there a gasket SET available or do I need to order them piece meal?
Also, can you tell me what gaskets are needed?
01 XK8
PS: already have tensioners and WP.
Old 05-01-2013, 04:57 PM
Paul Pavlik's Avatar
01 XK8
This Gasket set is for the Valve Covers and includes the small seals for the Cover Mounting Bolts.
Of course, this is for the Secondary Tensioner replacement only:
RockAuto Parts Catalog
randyb (05-01-2013)
Old 05-01-2013, 05:02 PM
tberg's Avatar
Received 2,541 Likes on 1,412 Posts
If you go onto ebay and type in XK8 gasket in the search line, you will open up unto every conceivable gasket set for your car, some more extensive than others. When I changed my tensioners, I ordered the set from Christopher's on ebay.
Old 05-01-2013, 05:04 PM
randyb's Avatar
There is not a gasket for the timing chain cover?
Old 05-01-2013, 05:17 PM
The Chains are contained inside the (Valve or Front) Covers.
Replacing the Primary Tensioners would require removing the Engine Front Cover (MUCH bigger job) and then would require replacing (or re-using) the Front Cover Gasket.
Note: a alternate for the Valve Cover Gaskets is the Fel-Pro set:
Old 05-02-2013, 09:44 AM
randyb's Avatar
thanks for clarifying Paul
RoyLittle0
05-25-2023 02:38 AM
Jpav27
07-31-2022 06:43 AM
Bowman
09-15-2015 06:54 AM
KarimPA
09-12-2015 08:15 AM
Bowman
09-03-2015 03:17 PM
Quick Reply: getting tensioners replaced
