Glove box tool
Old Dec 11, 2020 | 07:46 AM
Dancer's Avatar
Default Glove box tool
Greetings all. New member here. I am helping my friend with her 2000 XK8. Her glove box was broken into some time ago. The latch striker plates appear to be misaligned. This looks like an easy fix with a "star" screwdriver of the right size. The latches also do not both fully, smoothly extend. This appears to require that the cover over the latching mechanism be removed in order to check for broken springs, bent parts, etc. The cover plate is held in place by what look similar to "pop rivets" but look like they might need a special tool to be removed. Unlike some trim parts of other vehicles I have worked on, these trim attachments do not appear to respond to "gentle prying". Does anyone know if a special tool exists to remove these "rivets"? Also it looks like removing the entire glove box would make this task easier. Any guidance on removing the glove box would be most helpful. Thanks so much. Aloha
Old Dec 11, 2020 | 11:05 AM
Pristine97XK8Convertible's Avatar
Post as many pictures as you think would help members to suggest solutions.
Old Dec 13, 2020 | 12:19 PM
PKWise's Avatar
Dancer,
Those look like proper ‘pop rivets’ and, unfortunately, there is no special tool to remove them. You will have to drill them both out (a 3mm drill bit should do it). Be careful not to drill right through the Lid !. Once you have repaired the latch mechanism, you will need to re-rivet the cover back on.
Old Dec 13, 2020 | 02:07 PM
Dancer's Avatar
Hi PKWise, Thank you son much! This is exactly the insight I was looking for. Always better to learn than re-invent the wheel. I really appreciate you taking the time to respond, sir. Have a great day. John
Old Dec 13, 2020 | 02:08 PM
Dancer's Avatar
Typo: Thank you SO much ;-)
Abacab
May 9, 2025 02:51 PM
Glendoramike
Oct 9, 2024 04:11 PM
Timeisrelative
Jul 6, 2019 02:40 PM
sws805
Dec 14, 2012 09:36 PM
ric
Jan 29, 2009 07:43 PM
