Green shower update
Old May 29, 2014 | 09:07 AM
pmc1907's Avatar
Default Green shower update
In the process of putting the XK8 back together after recovery from the"Green Shower". Couple of things: I purchased aftermarket hydrauliclines based on what other people had posted as negatives about the factorylines. The only drawback I came across is that if you go with aftermarketlines, you will also have to change the elbows on the locking block and thepump. This can add a couple of hours to the job overall. Also, I read wheresome people mentioned that you may not have to remove the center console.Unless someone has already messed with your Jag, you’re going to need to removethe center console. There are hose clips and areas where the lines are wiretied to the frame under the carpet.
Ok, so I have a question: On the passenger side behind the speaker grill Ifound this (see attached Pic). I think it is a thermocouple for the climatecontrol system. Can anyone Identify this?
Thanks in advance.
Old May 29, 2014 | 09:16 AM
WhiteXKR's Avatar
Thanks in advance.
It is a wire antenna for the remote.
Old May 29, 2014 | 09:17 AM
Dennis07's Avatar
I have not been through a hose replacement, but I believe there are one or two vendors of aftermarket hoses that work with the existing elbows. Never made sense to me to have to change the elbows.
Old May 29, 2014 | 09:25 AM
Artigiano's Avatar
I used replacements from Top Hydraulics. A straightforward direct fit, even for the funny clip-connection for the RH lift ram
Pristine97XK8Convertible
Mar 5, 2025 10:32 AM
MrWhite
19
Jun 14, 2022 07:49 PM
Sonnyblack
Oct 4, 2015 05:42 PM
Jaguar Forums Editor
Jaguar Press release
Sep 30, 2015 03:08 PM
aadjei
Sep 25, 2015 03:07 PM
