hard reboot
Old Apr 1, 2018 | 01:18 PM
magnum454's Avatar
Default hard reboot
How is a hard reboot done on 2000XK8?
Old Apr 1, 2018 | 01:39 PM
jeremys's Avatar
You will find a good write up of the hard reset procedure in the sticky /diy just below the audio section, hope this helps
Jeremy
Old Apr 1, 2018 | 01:40 PM
RJ237's Avatar
Disconnect the negative cable at the battery and touch it to the positive terminal for 15 sec.
Old Apr 1, 2018 | 03:34 PM
Gus's Avatar
Gus
Use this link to see how to do it.
Old Apr 1, 2018 | 05:37 PM
Now you know HOW, the obvious question has to be WHY do you want to do a hard reset?
It will only reset 'learned' settings such as fuel trims to default values and isn't a method of clearing error codes.
no support
40
Jun 26, 2017 02:04 PM
jimlombardi
Oct 27, 2011 09:11 PM
edtexas
Jan 18, 2011 10:21 PM
govatos
Aug 9, 2010 08:40 PM
JamesWalker
Apr 28, 2010 09:48 AM
