Hard reset?
Old Aug 13, 2016 | 01:41 PM
Richxk8's Avatar
Default Hard reset?
Does doing a hard reset clear "C" as well as "P" codes or do "C" codes have to be cleared using WDS, etc?
Old Aug 13, 2016 | 01:54 PM
If only DTC's were that easy to remove!
A hard reset doesn't even clear Pxxxx codes. It only resets learned settings in volatile memory such as fuel trims back to default and window travel limits.
Old Aug 14, 2016 | 10:29 AM
Richxk8's Avatar
That's what I thought. If the part has been repaired will the CEL/DTC eventually reset or must it be done using the factory software?
Old Aug 15, 2016 | 02:16 AM
JagV8's Avatar
Depends what the fault was.
Old Aug 15, 2016 | 10:49 AM
Richxk8's Avatar
I have a "C1137" ABS Module Failure. Had it repaired but since I still have the C1137 code not sure repaired module is good. So, should I just go have it reset or wait for several drive cycles. Only issue now is no ABS, Trac or ASC. Still drivable.
kingnero
May 5, 2020 12:46 PM
Softball60
Aug 4, 2016 05:05 PM
Anthony8858
Jul 25, 2016 11:06 AM
max224
Jul 19, 2016 08:17 PM
peeterak
Jul 18, 2016 01:10 PM
