Harsh Ride
Old Apr 27, 2024 | 04:57 PM
Rex's Avatar
Rex
Default Harsh Ride
Went for a drive today and the Admiral was not happy with the ride quality. All previous Jags were XJ12’s, XJS and 4.0 S Type Sport, all very smooth ride. How do I go about improving the ride quality of the XK8?
Old Apr 27, 2024 | 05:22 PM
zray's Avatar
First investigate what’s worn out. You will likely need upper shock mounts. A forum member manufacturers them, and they will last, unlike the commercial offerings which are lucky to last one year.
A-arm bushings are another area which deserves examination. The sway bar (anti roll bar) also has rubber bushings that wear out early on.
Then there’s shocks and springs to check out too.
if you have the repair or maintenance history of the car that’s helpful in determining the age of these parts.
Z
Old Apr 27, 2024 | 05:26 PM
baxtor's Avatar
What are the wheel /tyre sizes?
Old Apr 27, 2024 | 06:18 PM
Rex's Avatar
Rex
All parts are original, have full service history, 118,000 km.
Old Apr 27, 2024 | 06:20 PM
Rex's Avatar
Rex
17” rims. 225/55/17 tires. Yes, undersized.
Old Apr 27, 2024 | 06:39 PM
zray's Avatar
Has anything been replaced yet ?
Old Apr 27, 2024 | 07:03 PM
Rex's Avatar
Rex
Nothing, all original.
Old Apr 27, 2024 | 08:28 PM
zray's Avatar
At the very least, it’s a safe bet you are in sure need of upper shock mounts and anti-roll bar bushings.
As mentioned previously, a through examination of the entire suspension system is called for. Only then will you know where you stand.
Z
PS: talk to Wayne ( member : cjd777 ) for the upper shock mounts. He’s done the homework on those
https://www.jaguarforums.com/forum/xk8-xkr-x100-17/wayne%92s-front-shock-mounts-279665/
a quick search on the forum will demonstrate how well they are doing vs every other upper shock mount.
Old Apr 28, 2024 | 03:39 AM
Redjags's Avatar
Tyre pressure?
Old Apr 28, 2024 | 09:58 AM
Rex's Avatar
Rex
Originally Posted by Redjags
Tyre pressure?
That will be the fist move! Currently 32/34, will reduce and see if that works, thank you.
Old Apr 28, 2024 | 08:42 PM
Rex's Avatar
Rex
Reduced tire pressure to 26/28, noticeable difference in ride quality. Jacked it up and had a good look around and could find nothing wrong. It then occurred to me that all previous jags wore Michelin (usually Pilot Sport AS), this one has Bridgestone Ecopia 422 plus. Could it be the tires that are messing with the ride quality?
Old Apr 29, 2024 | 12:07 AM
Kuddlesworth's Avatar
Could very well be the tyres.
Old May 5, 2024 | 05:08 PM
Rex's Avatar
Rex
Took the wheels off and did a very close inspection of all suspension components. All good. Only possible cause are the tires. Reduced pressure to 26/28 and ride acceptable. No cost solution.
Old May 5, 2024 | 06:58 PM
waltwagner's Avatar
Pressure that low, while providing a cushier ride, might cost you excess and uneven tyre wear.
Old May 5, 2024 | 07:06 PM
Rex's Avatar
Rex
Would then justify getting Michelin pilot sports, as I am used to.
Old May 6, 2024 | 12:46 PM
I think for 18" wheels the tyres should be about 29 psi all round, at least that is what I have been told will stop the tyres from wearing uneven.
Old May 6, 2024 | 01:57 PM
Jon89's Avatar
My wife's 2006 XK8 with 19-inch wheels and tires performs best with 32 to 33 psi in the front tires (245/40/19) and 28 to 29 psi in the rear tires (255/40/19). I spent about a year experimenting with tire pressures after we acquired the vehicle in early February 2012 before I arrived at that conclusion....
Old May 6, 2024 | 04:24 PM
Redjags's Avatar
The tyre (tire) inflation table, on the underside of the armrest gives all the different pressures for the various size wheels. Interestingly it also has the statement, on mine at least, that if you are not using the OEM tyres (Pirelli PZeros in my csse) you should inflate your tyres to 40 psi!
I did that just to see what the ride was like. I think the designer of that label produced it on the first of April! I run mine at 32 all round. Works for me.
Old May 6, 2024 | 07:04 PM
Rex's Avatar
Rex
17” P Zero no longer available.
Old May 6, 2024 | 07:12 PM
baxtor's Avatar
I think your thoughts re switching to michelins has merit. I have 20" all round and was running federal evoluzion tyres, while very happy with performance they did feel a little harsh. Changed fronts over to pilot 4s and the increased refinement is quite noticeable.
