Headlight lens removal
Old Jul 28, 2010 | 02:44 PM
JockeF's Avatar
Default Headlight lens removal
Hi all Jaglovers!!
I need to replace the headlamplens on the right side. Tried to search the forum but could not find any threads how to do it.
Regards.
Joachim
Old Jul 28, 2010 | 07:31 PM
WhiteXKR's Avatar
This thread should help you remove the headlight assembly: https://www.jaguarforums.com/forum/s...ight=headlight
Once it is out, gently pry up the tabs separating the lens housing and the body of the headlight (I think there are 2 or 3 on each long side and one on each end). The lens and the housing will then separate, it will be helped automatically by the rubber gasket pressure. Replace the lens with the new gasket it comes with.
Old Jul 29, 2010 | 12:25 AM
JockeF's Avatar
Thanks for the link and the quick response.
Regards
Joachim
Old Jul 30, 2010 | 01:28 AM
JockeF's Avatar
Hi
The Lens (reflector) are they the same on both LHD & RHD cars?
It`s clear glass but I am not sure!
Joachim
Old Jul 30, 2010 | 09:32 AM
WhiteXKR's Avatar
I think they are the same for LHD and RHD. But there are different part numbers for with and without headlamp washers. This must be specified when you order the lens.
1LowCat
Sep 14, 2015 07:51 PM
1964Daimler
Sep 9, 2015 11:28 AM
avern1
Sep 8, 2015 06:25 PM
avern1
Sep 6, 2015 04:22 PM
laserguy
Sep 3, 2015 02:02 PM
