HELP! Handbrake cable equaliser
Hi guys,
Just replaced the diff input pinion oil seal. Needed to remove the handbrake adjuster nut and equaliser to drop the driveshaft. Problem is I can't remember which way the equaliser goes back.
One side is flat, the other has a raised "bump" on it. Does the flat side face up or downwards? Thanks for any help you can give me.
JimC64
Oct 13, 2015 07:08 PM
