Help - Low Coolant level
Old May 9, 2011 | 01:33 AM
tramirez's Avatar
Default Help - Low Coolant level
I have 98 XK8, several months ago i developed a leak on one of the hoses to the Heater. So i replaced the hose and the thermostat housing. But poor manuafcturing on the thermostat housing, leaking on the top, i replaced it back to the OEM. Everything looks good no leaks. Now everytime the vehicle cools off, i have calapse hoses, low level coolant warning. Again no leaks that i can detect, but the antifreeze is being dumped into the atmospheric bottle under the right fender. Help anyone!!!!! a dealer mention to me to change the thermostat, i did. I even changed the antifreexe reservour and cap. No luck.. I also replaced all of the clamps, just incase one of them was bad. Any ideas.
Old May 9, 2011 | 01:59 AM
test point's Avatar
The simple answer is to 'rent' a set of coolant system pressure testing equipment from a local auto parts store. Pump up the system cold and the leak should be evident.
Wolfy
May 28, 2024 08:06 AM
Forcedair1
Feb 19, 2020 01:51 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Vee
Sep 13, 2015 12:19 PM
1100me
Sep 7, 2015 06:26 AM
