Help needed!
Old Nov 27, 2016 | 07:51 AM
XKJohnny's Avatar
Default Help needed!
My reverse light is out on my 2009 XK. I see two nuts holding it in but when removed still attached. Is the more under the trunk lid liner?
Now I am reading that it is by design that there is only one reverse light and one is supposed to be out! Is this a fact?
Old Nov 27, 2016 | 08:12 AM
dennysjag's Avatar
On my 2000 xk8 all of the rear lights are in one fixture , cluster. There are two plastic retainers that stick through the assembly. You just move them sideways a little bit and the whole cluster should pop off.You may have to fiddle with the carpet that is up against it. You should not have to remove any screws. The bulbs are push and turn type sockets.
Old Nov 27, 2016 | 08:49 AM
XKJohnny's Avatar
I have a 2009. Should have added that. Thank you.
Old Nov 27, 2016 | 09:00 AM
jimbov8's Avatar
Access is through the back and inside the trunk. Check the manual for further details.
Old Nov 27, 2016 | 05:21 PM
Originally Posted by XKJohnny
My reverse light is out on my 2009 XK. ......
Welcome to the forum XJJohnny,
Wrong forum. This is the 1996-2006 XK8/XKR forum.
