Help with thermostat tower leak
Old Dec 29, 2019 | 05:11 AM
flukinfool's Avatar
Default Help with thermostat tower leak
Finally traced back an annoying leak to the top of the thermostat tower.Seems the metal connector ( L shaped) picks up the hose that returns to the coolant tank. Leak is where the L piece fits into the tower.Didnt want to break anything by just pulling on it.Perhaps someone knows how to remove and what kind of sealant is used.Thanks in advance,will try to post a picture of the area.
It’s the tall piece at about 11 o clock on the photo.
Old Dec 29, 2019 | 08:13 AM
You need to replace the thermostat housing, it's a common fault a search will find a lot of info.
There is an aluminium housing available for the early cars but you need to use the OEM plastic unit. (might be a good idea to list the car details in your signature)
Here is a thread documenting the replacement thanks to RD https://www.jaguarforums.com/forum/x...ng-how-148856/
Old Dec 29, 2019 | 02:54 PM
flukinfool's Avatar
Thanks Norri,I appreciate the reply.Any chance you have a part number or supplier that is helpful to the diy guy.I will order the intake cover gasket as well.Anything I am missing or should tackle while there.Thanks much,Dave
Old Dec 29, 2019 | 05:39 PM
Johnken's Avatar
Hey dave, how did you ID the leak? I'm hunting for a slow leak from somewhere, will take all the info I can collect.
Thanks, John
Old Dec 29, 2019 | 06:08 PM
I just did mine, I got it from SNG Barratt part #AJ89486 $123.37 all in including the forum discount.
I didn't take the cover plate off. Here's a link to their page. https://www.sngbarratt.com/us/#!/Eng...b-f82e6a297bc5
Old Dec 30, 2019 | 06:01 AM
flukinfool's Avatar
Hey john,I am a plumber by trade,so I took the primitive approach.Filled the coolant tank to about 3/4 full and used about 14 psi from my compressor to pressurize system.I had a old coolant tank cap with a homemade valve to feed air into system.I did it cold and removed the plastic intake cover-that revealed the leak.Kind of funky set up,but it worked for me.Just delighted it wasn’t one of the valley hoses.That will be my next project.
Old Dec 30, 2019 | 06:05 AM
flukinfool's Avatar
Thanks Norri,will order part today.Happy New Year to you and all.
04vdp
Oct 16, 2016 10:10 PM
Nee_the_Bogeyman
May 8, 2016 07:25 AM
mikeeadyjr
Sep 3, 2014 12:31 PM
XJ8JR
Mar 5, 2014 04:16 PM
morales8416
Mar 12, 2009 02:42 PM
