high beam sounds horn
Old Mar 23, 2022 | 11:56 PM
baxtor's Avatar
Originally Posted by moosejr
So,,, first, thanks to everyone for their input. I have successfully resolved the issue, , ,and learned a few things. . .
1. That bolt by the A/C drier does not exist on my car.
2. I have never seen where they separated grounds like they do in the wiring diagram for this car. That is why I as having so much trouble understanding what was going on, ,,two different ground connections going to the same light housing.
3. There is no lug or pigtail of any kind, that I could find, on the passenger side of the car. My build date is 7/99, so unless there was a mid-year change in the wiring harness, ,,or maybe a previous owner did a harness change, , ,I don't know.
4. I ruled out the combination switch because I would get the same horn sounding when turning on the fog lights.
Ultimately, I back-chased a ground from the left headlight housing to the ground point below the fuse block on the left fender,, ,and all is good. I hesitated to do this because I hate to put a band-aid on a problem instead of fixing the original problem. In this situation, there is something wrong in the wiring harness somewhere, but this patch is the only way I can see to resolve it.
Thanks again.
Good to hear problem is resolved.
Makes no difference now but that ground point shows as far back as '97 so maybe a panel repair or such might account for it missing. The earth wire circuit for those lights did change slightly at Vin #024687 but l would think that's well before your car.
PeteK812
Mar 13, 2022 05:08 PM
Redline
Nov 10, 2017 02:26 AM
Nemisis
Oct 6, 2012 11:31 AM
tvn300
Feb 13, 2010 07:48 AM
jvegas
Sep 10, 2008 07:35 PM
