XK8 Power steering pump ?
Old Jan 21, 2013 | 10:47 AM
Blackcat97's Avatar
Question XK8 Power steering pump ?
Well, My power steering pump is trash. I tried just installing a new gasket on the pump but it ended up turing my garage floor into a 'slip n slide'. The new pump is on its way but I am having a very difficult time removing the hose that attaches to the bottom of the pump and runs toward the rear of the car.
ANY HELP PLEASE ??
Does this require a special too ? I just simply see two nuts, one smaller, one larger, directly on top of each other where the hose attaches to the pump.
Old Jan 21, 2013 | 01:00 PM
mike66's Avatar
If that is the outlet hose that you mean, it is a length of metal tubing mated to a hose. The smaller nut is the one you need to turn, while holding the larger from turning. If they both turn, then you'll kink the tubing. Spray that tubing and small nut with the penetrating oil of your choice and hopefully you can free it up. JTIS shows either a washer or o-ring in there but doesn't label it, so watch for it.
Old Jan 22, 2013 | 07:58 AM
Blackcat97's Avatar
I thought that was the case (turning the smaller nut). Thank you for the advice. I will do just that hopefully it will separate. Thanks !
Old Mar 17, 2022 | 09:38 PM
oldjaglover's Avatar
And, so......what happened?
Remember that even these older threads are used for reference or solving similar problems.
That said, how did you get to that fitting? Did you loosen or move the pump to get at the HP hose fitting, or did you have a leprechaun get under there with a tiny wrench?
Ken
Old Mar 24, 2022 | 03:35 AM
Because these threads last forever and many owners need answers to the same problems you encountered, the results need to be shared on the forum.
So, what did you do?
How did you get it off?
Did you have to remove the bolts and turn the pump so you could get to the flare nut first, or did you do it with the pump still bolted on?
How and what kind of wrench did you use?
Then, how did you get it back on??
Thanks,
Ken
oyster
Feb 20, 2023 04:58 PM
banar
Mar 31, 2022 02:07 PM
97x306
Jun 27, 2015 12:17 PM
magmedia
Apr 2, 2015 09:22 PM
kats98
Nov 23, 2013 03:53 PM
