hissing sound under the hood when locking
Old Jan 23, 2013 | 03:05 PM
keestanis's Avatar
Default hissing sound under the hood when locking
With the '97 XK8 convertible nicely tucked away in the garage for the winter, today I noticed that after arming the security system with the remote key, there's a hissing sound (somewhat like a boiling kettle) coming from the right front corner of the engine bay. It will die out slowly after about a minute, and starts again when the lock key on the remote is pressed again...
Pretty spoogy, right? Anyone any clues?
Thanks,
Kees
Old Jan 23, 2013 | 03:32 PM
Jon89's Avatar
Do you see any fluids puddled underneath the front end?
R134a refrigerant hisses when it escapes from an HVAC system, but once there's a leak it all escapes in a matter of a couple of minutes or less....
Escaping coolant can also hiss, but usually only when the coolant is hot....
Old Jan 23, 2013 | 03:50 PM
keestanis's Avatar
Default fortunately no leakages
The garage floor is dry and clean. The Jag has been hibernated for a couple of months now, I only unlock her every now and then to smell the leather...
Wonder if one of the security features (e.g. brakes) is being armed when the sound emerges. As I mentioned, it's almost like a kettle boiling, but initially I thought it was sparks from some short circuit....
Daim
Nov 28, 2016 09:28 AM
XJsc-guy
Nov 23, 2015 01:56 PM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
jagent
Sep 12, 2015 09:10 AM
