Hitch on the XK8
Old Aug 30, 2012 | 02:21 PM
mp5802's Avatar
Default Good job.
Nice.
So, you had to cut a notch or hole in the bumper?
- Mike
Old Mar 24, 2013 | 04:32 PM
Savage's Avatar
Thumbs up Ok guys I'm ready for the attack!
1946 Classic Gar Wood Runabout $
2006 Jaguar XK8 Loaded $
Being able to enjoy the ride and the boat show....... Priceless!
Old Mar 24, 2013 | 04:50 PM
Kevin D's Avatar
The only thing that I would say, as I suspect that you know, is that I would recommend that at highway speeds, I would not put it into overdrive.
I think that you have a six speed in a 2006. I'd recommend that you go no higher than 5th gear.
I am no Jag transmission expert, as some on this forum actually are, but I do know that in my other vehicles when towing my boat, after blowing up two transmissions by towing in overdrive, I was told that the overdrive gear in a car is not designed to take the stress involved with towing a boat.
I am not sure, but I suspect that the same would be true for your Jag transmission.
Old Mar 25, 2013 | 06:22 AM
Cat888's Avatar
Priceless! LLOLL...
Old Mar 25, 2013 | 06:54 AM
Frog's Avatar
Only in America would you see a combination like that ^. I love it
Old Mar 25, 2013 | 07:32 AM
How does it cope on the launching ramp?
Old Mar 25, 2013 | 06:54 PM
Savage's Avatar
Default No launch
This is for the ride there only. Car is MUCH to low to launch on most ramps and I would think you would have to get water in the trunk before the boat would float. My buds from the boat shows launch for me. I have only taken it for short runs but am going to the Apalachicola Boat and Classic car show in April about a 4+ hour trip. Wish me luck!
Old Mar 25, 2013 | 07:03 PM
  #28
Bon Voyage!
Old Mar 26, 2013 | 04:51 AM
Very nice, Savage.
Good luck, but we will expect some decent pictures as well.
Old Apr 21, 2013 | 02:32 PM
  #30
Savage's Avatar
Default Tow was FANTASTIC!
Mileage: 245 mi (One Way)
Time: 4 hours 40 min
Gas Mileage:This shocked me, I expected less- 20 MPG
The transmission guide from ZF said that the "transmission controller (computer)would sense the towing load and adjust the shift points accordingly" and while reading this I thought "yea". Well blow me down this thing shifted wonderfully and did not hunt at all! The guide did not say to not tow in overdrive but I did not feel comfortable doing that and left it off.
Man this thing blew my mind with how well it did.
Absolutely gorgeous drive with the top down-Fabulous weather and the boat won "Best of Show- Restored"
Pictures will follow
IT JUST DON'T GET MUCH BETTER THAN THIS!
Old Apr 21, 2013 | 03:05 PM
  #31
Kevin D's Avatar
Congratulations all around.
If they had had a category for boat/tow vehicle, you would have, no doubt, won that too!
And, BTW, that is amazing mpg, especially in 5th gear. I think that was a smart decision not to tow it in 6th.
Old Apr 21, 2013 | 04:39 PM
  #32
Congratulations!
Old May 25, 2014 | 11:30 AM
  #33
franksm's Avatar
Hi lads
I am blown away by Savage's photo of the XK8 + Gar Wood combo. Ridiculously fantastic.
I had a nice bike-rack setup on my now-retired MX5, and want to do the same with my XK8 coupe. Looks like the Curt product will fit the bill !
One question, though: does the rear bumper need removed to do the drilling ? Or can it all be done from underneath ?
Attached Thumbnails Hitch on the XK8-wales241430_10150176679823509_5013121_o.jpg
Old May 25, 2014 | 03:46 PM
  #34
TreVoRTasmin's Avatar
Originally Posted by franksm
Hi lads
You should be able to print directions for the install via Curt's website. I know on the XJR x308 everything was done underneath.
Old May 26, 2014 | 04:21 PM
  #35
Savage's Avatar
I had no problem installing without removing the bumper. I used a Dremel tool and cut to the center of the hitch where it hit the bumper and worked my way out until it fit nicely. If you do not notch the bottom it does require you reach under the bumper to attach the chain if you need them. If your not towing , bike rack, basket, etc. it does not matter.
Old May 26, 2014 | 04:23 PM
  #36
Savage's Avatar
I will try and get closer under the car shots in a few days.
Old May 26, 2014 | 05:00 PM
  #37
franksm's Avatar
Thanks, appreciated. In the Curt diagram, it looks like the bolts are into the box section behind the bumper, and that's what needs drilled (bolt #2 in the pic)
My bumper has been Tigersealed into place in the wheel arches, as the brackets had disintegrated with rust. So, I want to avoid removing the bumper if possible. Awful story with rust on Irish and UK cars.
Old May 27, 2014 | 06:56 AM
  #38
Savage's Avatar
Shame to hear about the rust, don't have much rust in my area..... not much ice salt on the roads in lower Alabama. Because I was towing a boat I did put a aluminum strip bar across the inside trunk and drilled through it. Felt it would give the bolts much more surface area for support and with a rust problem it might be something to consider in your case.
Old May 27, 2014 | 07:29 AM
  #39
v8deuce's Avatar
Originally Posted by XKRacer
I have a strange urge to hire a hitman and send him to Canada!
LMAO
Randy
Old Jun 12, 2014 | 04:26 PM
  #40
franksm's Avatar
Just in case anyone is thinking of ordering from Trends Auto - don't, you'll have your hands full with trying to get them to send anything after they take your money. Luckily the credit card company stepped in.
So I tried HitchAnything.com...
Two weeks later, money taken, nothing sent, lots of promises. I will let you know how it goes with them, but just take care if you are thinking of using them...
