Hoping someone can help with Headlight issue
Old Jan 12, 2013 | 08:50 PM
Ranmaninfl57's Avatar
Default Hoping someone can help with Headlight issue
None of my Left headlight bulbs come on except HighBeam. Checked Main Bulb it looks good. Fuses are good. Is there a relay that could be the culprit? If so where is it located? Apprecieate the help!
Old Jan 12, 2013 | 08:53 PM
Default Sorry...2002 xk8
Guess it helps to mention the caI asking for help with
Old Jan 12, 2013 | 09:13 PM
WhiteXKR's Avatar
There is a low beam relay, but it is shared on both sides. If the relay was the problem your right side would be out also.
Double check that bulb, and also the separate left low beam fuse, #8 (10 Amps) in the engine compartment fusebox.
Old Jan 12, 2013 | 09:23 PM
Thanks will swap bulb with right one to check. I did check Fuses#6 and 8 and they are good. Problem though all three bulbs in left headlight assembly do not work. Only the High Beam. Left turn signal works and Left Fog Lamp works.
Old Jan 13, 2013 | 05:23 PM
NikasilNik's Avatar
Wile you have the bulb(s) out , check there is power to the connector and make sure the earth(ground) is good
Hope this helps
NikasilNik
JarodL
Mar 7, 2024 01:39 AM
mcdutch
Sep 4, 2015 03:38 AM
Busa R
Sep 3, 2015 05:01 PM
laserguy
Sep 3, 2015 02:02 PM
King Charles
Sep 3, 2015 12:40 AM
