How bad is your condensation?
Old Mar 10, 2018 | 02:26 PM
renaultvation's Avatar
Default How bad is your condensation?
As you can see from the photo, I have a bit of a condensation issue, so having read the 'stickie' thread on the subject though I had better do something about it.
Using a hairdryer, I removed the condensation, but revealed a lake in the headlight bowl. Using some micro-bore pipe, I removed the water, then set about it with the hairdryer again to remove all moisture
The final photo shows the finished result. I need to provide a more permanent solution by fitting a drain, but will also try silicone grease on the cover.
Old Mar 10, 2018 | 05:35 PM
Johnken's Avatar
Wow tough job. It's a wonder that you didn't blow the white hot headlight every time you hit a bump!
John
Old Mar 10, 2018 | 05:49 PM
We've had a lot of rain in the UK over the past few months but that's way beyond condensation. The seal between the shell (item 1) and the lens (item 2) must have failed.
Remove the headlamp and separate the lens from the shell by releasing the clips (arrowed in red). The lip (arrowed in blue) can then be sealed with silicone and the unit reasembled.
Another route for water entry is a loose access cover (item 3).
Old Mar 14, 2018 | 05:02 PM
I think your diagnosis is correct. A couple of days later and the headlight is full of water again and I haven't even used the car. Looks like I shall be taking it apart to reseal it.
H20boy
Aug 8, 2014 05:04 AM
philhef
Jun 15, 2013 05:21 PM
jagxkrtoofast
Apr 15, 2010 01:11 PM
bmw745ion19s
Sep 25, 2007 10:13 PM
