How to tell which A/C Condenser to use?
Old Sep 29, 2019 | 08:03 PM
AC0FC's Avatar
Default How to tell which A/C Condenser to use?
In doing some other work, I had to remove the A/C condenser The fins were all smashed-in from ingesting too much snow in the nose (yes I drive in snow).
Now looking for a replacement, I find that there are 2 possible condensers?.
Nissens A/C Condenser - Front
Part Number: 639-05805551.
and
Click to Enlarge
Part Number: W0133-1657522Notes: May require updated hoses/pipes, if vehicle has not been updated. 1)MJD 7361AA, 1)MJD 7341AA, 1)MJD 7340AB
Features:
  • OEM Quality Direct fit Application
  • Utilizes fixed feeder tubes with no fault tolerance in length, diameter and bending angle, providing protection against leaks and loss of efficiency.
I'm the 3rd owner and have no idea what A/C work has been done in the last 22 years and 138,000 miles. How do I tell if I have original or updated hoses etc?
Old Oct 1, 2019 | 06:34 PM
michaelh's Avatar
Nissen's website shows (their part #) 94798 as correct up to '99, and is the one I fitted to replace the leaking OEM. Rockauto has it:
https://www.rockauto.com/en/parts/ni...condenser,6708
The part numbers quoted by partsgeek for W0133-1657522 relate to the 99-02 cars according to both SNG Barratt's catalogue & JEPC so you want pg's part # 639-05805551, but I'd contact them to confirm.
HTH
RaceDiagnostics
Aug 27, 2021 06:57 AM
XXXAngelXXX
Oct 11, 2016 09:24 PM
Lizard
Aug 15, 2015 02:10 PM
exexpat
Mar 6, 2011 03:47 AM
Riski
Sights N Sounds
Feb 4, 2010 01:32 PM
