I need this rubber seal
Old Dec 31, 2010 | 04:39 PM
brgjag's Avatar
Default I need this rubber seal
On my 97 Xk8, the pass side where the computer and the trans controllers are located under the black cover. When on that area there are 4 pc's of rubber that goes around the opening. I need the one that runs along the fender side.
Old Dec 31, 2010 | 04:47 PM
brgjag's Avatar
check that, just two pics. I need the short pc that runs on the fender side of the opening.
Old Jan 1, 2011 | 11:54 AM
H20boy's Avatar
pic...I have no idea to what you are referring surely you can 'fabricate' a trim piece?
Old Jan 1, 2011 | 06:33 PM
brgjag's Avatar
I meant piece. I will take pic later.
Old Jan 4, 2011 | 05:52 PM
daddyo007's Avatar
Is it the bulb type that is also around the trunk rim? You should be able to get something from the bone yard. Look around to see if the seal is elsewhere on the car. Then go boning.
Old Jan 4, 2011 | 09:00 PM
hlgeorge's Avatar
Is this the one? If so I have some lengths from a RR hood seal that work great. This is what I have on mine. Tell me the length and I can send you some.
robbing
Mar 5, 2024 10:51 AM
Buckingham
Jul 6, 2016 11:09 AM
prettydaim
Nov 12, 2015 08:05 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
